cam wear marks little rough
Old 07-28-2009, 11:36 PM
themack56's Avatar
Default cam wear marks little rough
ok i have a g5x4 cam and its pretty rough on the lifter portions. can a machine shop buff this out or something like that to make it nice and smooth again?
Old 07-29-2009, 10:12 AM
Hell'sChariot's Avatar
Why is it rough? Either the cam wasnt made properly or your lifters are poo and need to be replaced.
I doubt a shop can fix it without messing with the cam specs. Fixing it would require removing material and that would throw everything out of wack.
Old 07-29-2009, 10:37 AM
z28mccrory's Avatar
I had a cam do that exact same thing. It was very prominent on one lobe in specific.
Unfortunatly, there isn't much you can do about it. I heard that certain cam blanks had soft spots in them, and thats what causes it.
Old 07-29-2009, 11:18 AM
vettenuts's Avatar
If you are through the hardened surface you likely have a paper weight.
Old 07-29-2009, 12:56 PM
digitalsolo's Avatar
You can make a nice lamp out of it, unfortunately you don't have a lot of other options.
Old 07-29-2009, 04:53 PM
02*C5's Avatar
If your cam lobes look like the first cam lobe...
Your in deep ****. The guy who did my head cam set up was highly regarded by a man who has been in the business for years. The guys is no more than an amateur. All my intake lobes are cracked, w/ deep wear marks after 5,800 miles only yes 5 thousand eight hundred only. The shop is out of Dallas Texas if any one wants to know where not to take their cars to shoot me a pm I'll tell you my night mare. Which consisted of a leaking front plate gasket, leaking heads, a tune that would have surely made my engine blow if a true professional would not have rectified it, and on and on and on... The best part the guy is not taking any responsibility for his shitty work.
