Drag Racing Tech
What Transmission Shield You Guys Running?
Old 07-29-2009, 11:53 AM
Reboot's Avatar
Default What Transmission Shield You Guys Running?
I posted this in the automatic transmission section and got no response. This section seems more appropriate to ask this question.
I have a TH400 with Utrabell and I'm currently running a blanket to shield the drum area. The date is up on the blanket and I was thinking about using a bolt on shield.
Which shield will fit the tunnel without having to be clearanced? (TCI, Art Carr, Etc.) I really want to do this with the tranny in the car, so clearancing may be a pain. The CSR covers the flexplate area and doesn't fit with the Ultraball.
Whatcha all running? Any good options?
Old 08-06-2009, 01:31 PM
Reboot's Avatar
Nobody running anything besides a CSR? Are you guys with Ultrabells not running a shield?
Thanks in advance
Old 08-06-2009, 04:09 PM
cambirdracing's Avatar
I got a hard shield (don't remember the brand) on my car and it is a pain in the a$$. Put a blanket on the wifes car and love it. Blanket is easier to work around.
Old 08-06-2009, 04:48 PM
Reboot's Avatar
I actually think the blanket is a pain. too tight and the car won't shift, too loose and it hangs down towards the ground.
Old 08-06-2009, 05:10 PM
tektrans's Avatar
CSR is light as hell. why use anything else?
Old 08-06-2009, 06:08 PM
Reboot's Avatar
it doesn't fit with the utrabell
Old 08-06-2009, 06:22 PM
tektrans's Avatar
Oh I see. The hard shields work well but you will have fitment problems for sure with the stock tunnel. I don't see any way you can get it on with the trans in place but then again I've never done it.
Old 08-06-2009, 06:40 PM
BassProCamaro97's Avatar
From what I've read on here it is very tough to get a metal drum shield to fit in the stock tunnel. You'll find most are running the CSR because it does both (Flywheel & Drum) and fits real well.
I think your best bet is to run another blanket. How often are you at the track that you need a shield on at all times?
~Jim~
Old 08-06-2009, 11:19 PM
Reboot's Avatar
This is a track only car. I guess I'll just do a new blanket.
Old 08-07-2009, 11:30 PM
trans2000am's Avatar
what do you have to replace the blanket every year or something? i still need to get a cover or shield
Old 08-08-2009, 12:45 AM
Reboot's Avatar
Blanket is good for two years. Not that they could ever tell because the tag is at the top of the tranny.
