Drag Racing Tech
Already searched. Heater hose outlet blockoff
Old 11-19-2003, 02:51 PM
Formerly 4mulaJoe
LS1x2's Avatar
Default Already searched. Heater hose outlet blockoff
I'm posting here thinking I might get a reply rather than the external engine section where it's mostly about bolt ons.
I ditched my heater core. I have a U-shaped tube blocking off the outlets on the waterpump for the heater. Does anyone have a better solution? I don't trust this one too well.
Old 11-19-2003, 02:55 PM
FEAR THE LS1's Avatar
I ran a u-tube/loopback hose on my stock water pump using the same OEM tube clamps that came with my car. Its been working great, I am now running a Meziere EWP(street version) and just used the same loopback hose and clamps, works great.
Is your leaking or anything? If not your good to go!
Lee
Old 11-19-2003, 03:24 PM
Formerly 4mulaJoe
LS1x2's Avatar
Lee
I just now got everything together. It was dripping b4 I tightened it. I will keep an eye on it but I'd like some kind of cap to put on them.
Old 11-19-2003, 04:38 PM
quickWS6's Avatar
I just looped one of the stock lines. Worked fine for me for a while. Now I run a Meziere race pump. I would have capped it off if I had found any caps that would fit just for a cleaner look.
Old 11-19-2003, 05:12 PM
Super Moderator
Reckless's Avatar
They have heater bypass caps in different sizes at Autozone. Just get a couple big ones. I think the small one is 5/8" and the bigger one is 3/4". Then just use regular worm clamps.
Old 11-20-2003, 10:03 AM
ROB'S SS's Avatar
i looped my hoses to cap them off as well. and that was about a year ago with no problems
Old 11-20-2003, 10:42 AM
LS1TECH Sponsor
Magnus's Avatar
I cut out an elbow section of the header hoses so it already had a bend in it and just re-used the factory clamps. Works good.
Old 11-20-2003, 03:41 PM
Motorboater
SilverGhost's Avatar
Looped the stock one here..no problems so far..might try the autozone caps for better looks though.
Old 11-20-2003, 04:57 PM
Super Moderator
Reckless's Avatar
That's why I used the caps. Looked a lot better in my cleaned up bay.
