Gaskets and seals
Gaskets and seals
I need to know what gaskets and seals I need to finish my engine build and swap. The engine is an ls6 and its going in an 02 Camaro. The shortblock came assembled. Thanks for any help you can offer.
Also need freeze plugs, oil plunger for back of block, freeze plug for front of oil on lower right side i believe, coolant pipe seals, etc etc. Are you re-using any covers or anything from the SS?
