comp cams Trunion Upgrade Kit quistions
Old 07-30-2009, 12:18 PM
Bader-X's Avatar
Default comp cams Trunion Upgrade Kit quistions
saw them on speedinc site 134.95$ are they easy to replace the stock rockers with? same as the Harland Sharp upgrade people do(technicaly and functionaly)?
I`m about to rebuild my engine and going to 6800-7000 rpm and my stock rockers have +120K miles and read that yella terra and harlan sharp need to be set up good and I don`t trust local shops to do that so I have the option or upgraded stock ones with harland sharp or buying those if they`re good and no need for a properly set up good thing.
thanks in advance.
Old 07-30-2009, 12:59 PM
ROCNDAV's Avatar
link?
Old 07-30-2009, 01:06 PM
Bader-X's Avatar
http://www.speedinc.com/catagory.cfm...etrain / Heads
in the middle
Old 07-30-2009, 01:17 PM
ROCNDAV's Avatar
Ah cool.
http://www.speedinc.com/cont.cfm?cid=C0000927
I wonder if different bolts are needed (or included as they are with the harland Sharp mod).
Old 07-30-2009, 05:29 PM
Bader-X's Avatar
I didn`t know that the HS ones needed that ^_^ and I`m asking about info on these
Old 07-30-2009, 06:15 PM
ROCNDAV's Avatar
Harland Sharp sends new bolts with the upgraded rockers.
Old 07-30-2009, 07:21 PM
00 Trans Ram's Avatar
Got mine done at Thunder. Here's some info:
https://ls1tech.com/forums/generatio...r-upgrade.html
Old 07-31-2009, 04:36 AM
Bader-X's Avatar
thanks very much
guess they`re good .... but maybe I`ll have them installed on a used set and sent to me
Old 07-31-2009, 09:02 AM
They weren't that hard to install. Just time consuming and delicate. I'd probably have them installed and sent to me, too.
Old 07-31-2009, 09:23 AM
383lt1impala's Avatar
I wouldn't trust my self on something so delicate. Ill try to give them a call maybe they can install them.
Quick Reply: comp cams Trunion Upgrade Kit quistions
