What oxygen sensors do you guys run?
Old 07-31-2009, 10:11 AM
TS6
TS6's Avatar
Default What oxygen sensors do you guys run?
I'm about to swap mine out for new ones, what have you guys had luck with? I realize this isn't nitrous specific, but there are some smart guys in here, I trust their advice.
Stock ECM, BTW.
Thanks
Old 07-31-2009, 10:15 AM
ShiznityZ28's Avatar
Doesn't matter they are narrow band and are useless for real tunning. get a wideband if you care to see the actual a/f
Old 07-31-2009, 10:31 AM
built408's Avatar
I don't use them at all.
Old 07-31-2009, 10:29 PM
5_02ls1's Avatar
me either....well my wideband...
Old 08-01-2009, 12:46 AM
jmill96Z's Avatar
Yeah, but they'll make for a rough day if one/both takes a ****.
Old 08-01-2009, 09:49 AM
TS6
TS6's Avatar
I just need to toss some new ones in, threw a code for O2 and figured they are probably old anyway, just wondering what you guys use. This isn't for tuning, just for the ecm to run on.
Old 08-01-2009, 10:35 AM
jmill96Z's Avatar
I ran the bosch O2's from the local parts store. IIRC, I ran the C5 part # because of longtubes. And they have a lifetime warranty
Old 08-01-2009, 10:50 AM
TS6
TS6's Avatar
The Bosch 13111's?
Old 08-01-2009, 10:53 AM
caviness's Avatar
yes that the ones.
Old 08-02-2009, 07:53 AM
n2ocamaro's Avatar
I use Denso in mine because they hold up to leaded race fuel (for awhile)
Old 08-02-2009, 09:57 AM
ATVracr's Avatar
Turn them off.
Old 08-02-2009, 12:52 PM
Z-RATED94's Avatar
How long is a while? Anyone switching O2s out just to use some race fuel at the track? Used ones at the track and new ones once the race fuel is used up? Sorry for the hijack.
Old 08-02-2009, 01:10 PM
jmill96Z's Avatar
I just use unleaded fuel. VP MS109 is some badass stuff.
Old 08-02-2009, 01:16 PM
johnLs1camaro's Avatar
I dont run them either, I went to open-loop because I was going through them too much. Im happy without them.
Old 08-03-2009, 09:33 AM
Thats why we don't ewven have them in. the stock ones die to easy. and an aftermarket 1 should be used to verify the plug reading.
Old 08-03-2009, 11:07 AM
n2ocamaro's Avatar
My last set lasted over 700 miles running mostly race fuel. I only put about 500+ street miles on my car per year.
Old 08-03-2009, 11:12 AM
camscam02's Avatar
we fianlly burnt one up at the track the other day after a crap ton of passes. Car didnt want to idle for its life but ran great on motor once they were shut off at WOT. Dont know if Im gonna put them back in to help driveability or leave it the way it is.
**** did go 125 mph on motor though so that was a plus.
Old 08-03-2009, 12:30 PM
LS1 SPEED's Avatar
used often here as well with good results
Old 08-04-2009, 01:33 AM
PONTIAC SLP's Avatar
which Densos you have there ? please give me the part # , thank u.
Old 08-04-2009, 08:06 AM
n2ocamaro's Avatar
I have an LT1 so I don't know if the part # would be the same for LS1.
Quick Reply: What oxygen sensors do you guys run?
