Strange whining upon exceleration...?
Old 07-31-2009, 10:20 AM
Daniel D's Avatar
Question Strange whining upon exceleration...?
Hey there!
Thanks in advance for any help you guys can provide - for the past couple days my ride has this whine it makes when I excelerate. It's coming from under the hood and it only does it when excelerating (not turning, braking, or de-excel) and the whine gets higher pitched the higher the RPM's??? I've never heard this on any other car I've had so I'm kinda stumped, any ideas??
GEARS cc
Old 07-31-2009, 10:28 AM
Trans Am Jam's Avatar
1st of all it's ACCELERATING...not EXCELERATING!!! now since that's off my chest a whine can be anything: a bad bearing, water pump, idler pulley, alternator, or the serpentine belt tensioner. What I usually do when identifying where the noise is coming from is by getting a long screwdriver or metal pole and while the car is running (if throttling it produces the noise then do it) and just place the screwdriver on various objects that you presume the noise to be coming from. the vibrations will act as a cheap stethoscope and alert you where the problem is. you need to give us more information such as which side of the engine bay and what not...
Old 07-31-2009, 10:43 AM
Daniel D's Avatar
Hey sorry for the grammatical error - I'm fricken tired and hung over so bare with me, hahahaha....
It's coming from the Driver's side, I'll try your screwdriver trick, thanks
Old 07-31-2009, 11:09 AM
no problem let me know what the deal is.
Old 07-31-2009, 11:17 AM
twitchtwice's Avatar
what kind of whining is it. do you have stock exhaust, it could be just the serpentine making noises. if this is your first v8 you will probably start noticing lots of different noises.
Old 07-31-2009, 11:18 AM
giantrules's Avatar
my wife makes that noise on accel between 5 and 6500 rpm lol
Old 08-05-2009, 10:54 AM
Daniel D's Avatar
hahaha - thats hilarious!
I'm now wondering if maybe its the Power steering pump??? I looked and the PS fluid housing is "messy" like its leaked but its level..? How hard is it the fix the Power steering pump/how expensive is that usually? would bad alignment mess the PS up?? Thanks for any advice!
Old 08-05-2009, 11:54 AM
z28camaross2's Avatar
yea my girlfriend seems to make the same noise whenever i like to give it some gas... hmm i like the sound of my car better
