5.3?
you can do a 383 rotating asembly...like mentuoned above the 5.3 can be bored safely to 3.89 bore but any further the block will need sonic tested....all 3 engines 5.3/5.7/and/6.0 share the same stroke...no need for a 6.0 that little 5.3 can be made into a monster...
i say dont bore it out (or bore it to 3.78) and throw in forged pistons and rods and a 4" crank and do something no one has done before and make a torquey 359 or bore it to 3.905 and do forged rods and pistons and put in a 4.8L crank and make a high revving 313ci motor
pistons
http://texas-speed.com/shop/item.asp...d=989&catid=38
rods
http://texas-speed.com/shop/item.asp...d=699&catid=39
crank
http://texas-speed.com/shop/item.asp...d=668&catid=37
im sure you could find a nice used 4" stroke crank on here for cheaper
with a set of 243 heads and a custom cam im sure this thing could be a beast
