Drag Racing Tech
Tires For A 16x8 Rim??
Old 07-31-2009, 07:49 PM
TORCHD 02 TA's Avatar
Arrow Tires For A 16x8 Rim??
Now i know i am on borrowed time with my 10 bolt, so i was thinking on getting a pair of DRs to throw on my 16x8 trans am rims...
Now here are my questions... Should i go with the following.... M/T, Nitto or BFGs??????
What size??? 255/50 or if i get M/T 26x10.5/16... Here is where i am confused. How can a 10.5" wide tire fit on an 8" wide rim?
Basically when the cooler weather hits here in Chicago, i am taking off my TTMs and throwing on my OEM wheels.. I pulled some weight, and with smaller tires (less rotational mass) hopefully i will get my 11 sec slip....
I've already ran a 1.9 60' (on my 17" TTMs with 315/35 Nitto STREET TIRES in the rear). My best time is a 12.30 @ 115.56 launching at 3k shifting at 6700....
Thanks for the help....
Old 07-31-2009, 08:34 PM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
the 255/50 radial will be what you use. plenty of racers use a 10.5 tire on an 8 inch rim (i run a 28 x 10.5 x 15 on a 15 x 8 inch rim).
Also, the ET Street bias ply 10.5 inch is not the tread width, it is the section width (versus an et drag where a 26 x 10 would have a 10 inch wide contact patch). The ET Street 26 x 10.5 is likely about 8.5 wide on the tread/contact patch.
Derek
Old 07-31-2009, 10:19 PM
well i need a tire to lower my 60's so i can get me a better E/T
Old 07-31-2009, 10:25 PM
Dan
Dan's Avatar
Get the ET Street drag radial 16", 255/50 like Villain said. I pull 1.60's all day long with them. A 1.56 was the best for me
Old 07-31-2009, 10:34 PM
The M/T E/T Streets? i thought that was only a 26x10.5/16 tire?? Or does it come 255/50/16 too?
Old 07-31-2009, 10:37 PM
TA1364's Avatar
If you get the ET street bias ply get 26x11.5. I have 26x10.5 and it needs a wider contact patch for sure.
Old 07-31-2009, 11:46 PM
does anyone have a link for the ET streets? I want to read up on them
Old 08-01-2009, 06:22 AM
7 Second Club
Remember to specify which ET Street you are looking for, as there is the ET Street radial and the ET Street bias ply (like a slick with softer sidewalls, grooves and a DOT rating).
M/T website: www.mickeythompsontires.com
Old 08-02-2009, 04:11 PM
So i decided that i am going to get the M/T ET Street Radial in a 255/50/16 size...
Old 08-02-2009, 04:32 PM
omcar's Avatar
Hey Dan how is it going out there in Ca? Sounds like you got your car running good.
Jay
Old 08-02-2009, 05:14 PM
Jay
Nothing like a good 'ol high jacked thread
Old 08-02-2009, 08:34 PM
Dan
Dan's Avatar
Jay
Sorry torchd You will love the ET Street Drag Radial. Doing good Jay, Have not raced the car to much. I need to get my *** in gear & maybe run the Summit Series at Famoso next year. You doing good?
Old 08-02-2009, 08:49 PM
paint it black vette's Avatar
hoosier makes a 255x50 x16 drag radial also. thats what im running 1.48's sixties on my car
Old 08-02-2009, 11:45 PM
johnLs1camaro's Avatar
Go with MT ET streets 11.5/26/16 they fit great on a 16x8 wheel. fit great on the car also.
Old 08-03-2009, 03:58 PM
omcar's Avatar
Hey Dan, doin ok but not as well as I'd like. Keep in touch.
Old 08-04-2009, 04:51 PM
slobird's Avatar
X2 I have those on my car on the factory chrome 16x8's and they hook great
