Drag racing with a 100k mile LS1
Old 08-01-2009, 01:18 AM
Fast 95 Z28's Avatar
Default Drag racing with a 100k mile LS1
Will I be safe drag racing my 100k 1998 LS1? I'm just putting in a MS3 cam, upgrading the valve train, and leaving the rest stock. I am going to put new piston rings, new rod bearings, and new crank bearings in the motor. I'm also getting the crank polished. Do you guys recommend doing anything else while the motor is apart. I'm kinda on a budget.
Thanks
Old 08-01-2009, 06:48 AM
JFM-jr's Avatar
Man your opening a door here that may have ALOT on the other side of it. Here are just a few things off the top of my head to do this right. As you stated crank will need to be polished,cylinders deglazed,block fully cleaned,main and rod clearances checked, rods all checked (with new upgraded rod bolts if preferred),new oil pump,new timing chain, i would change the cam bearings but a close inspection is the bare minumum. Gaskets alone for this job will be over 200 dollars. I am just finishing up my "Budget build" and the budget stretches by the day as you progress thru the process LOL. There stuff I left off this list I am sure others will help out here.
Old 08-01-2009, 01:01 PM
haha ya i understand how the budget slowly increases. My main question was will i be safe with a stock bottom end with 100k miles if i do everything i listed above? Or do you think I should buy some new pistons? I'm only looking for about 400-450hp.
Old 08-01-2009, 07:29 PM
callys's Avatar
Fast.... I just had my ls6 apart, it has 90k. My crank was damaged so I put a crank in it, new crank bearings, rod bearings, new stock rod bolts....cylinder walls actually looked really good, just needed a slight hone. I did a small cam and a tune at the same time.
I have been roll racing the car pretty hard with my brother and friends nearly every weekend. I am have run into some drivetrain problems and other small things like a wheel bearing.....but engine has performed flawlessly - they seem pretty unbreakable.
Old 08-01-2009, 09:27 PM
what were your cam specs? and what are you revving your engine up to? I only plan on revving mine to 6400 since that is where the MS3 cam makes its peak horsepower.
Old 08-01-2009, 11:27 PM
kinglt-1's Avatar
Ideally you should be reving out 2-300 more rpm past peak power. Imo that ms3 needs to be shifted at 6700.
Old 08-01-2009, 11:32 PM
crazymofo1986's Avatar
build the heads and do the cam. im at 150,000 n no prob yet. u might be causing more issues untill its needed.
Old 08-01-2009, 11:37 PM
Ls1Mx-5's Avatar
Glad to hear these Ls1's hold up like they do. My crappy 5.0 started burning oil at 125k.
Quick Reply: Drag racing with a 100k mile LS1
