Strange ABS issue after 9" swap
I recently put a 9" rear in my car, with 4.11s and a trac lock. I had abs reluctor rings pressed on to the axle for the abs. I also had the computer adjusted for the gears and other changes.
The problem is that the car sets off the abs light after about 1-2 miles of driving and it stays on. However when I let the car sit and start it up again.. the light goes off and then after 1-2 miles it sets off again!
Everything is hooked up and should work.. what is the issue?
Mine is doing the same thing. My 4-channel ABS worked fine before, but I figured my ABS rings must be different than the stockers to some extent. When you get it figured out let me know.
Is it a 3 channel? I was trying to chase down the same problem with my 9in. My rear ABS harness looked fine so I never replaced it. But after awhile I went to junk yard and got one for free. Turns out the plug that goes into car had connectors pulled out too far and didn't make a good connection. Now ABS works perfectly.
https://ls1tech.com/forums/search.php?searchid=8440440
