ASA Cam with 1.8 rockers, will ls6 springs work??
Old 08-01-2009, 10:33 AM
predator200289's Avatar
Default ASA Cam with 1.8 rockers, will ls6 springs work??
I got a LS1 with the GM ASA cam, im thinking about going to a 1.8 roller rockers. Im just wondering if my LS6 springs will still be ok to use or if i need to go with a different spring. Also wondering what the 1.8s would take my lift up to????
Old 08-01-2009, 01:05 PM
L33FTW's Avatar
dont have an answer for you, except that i know the max lift of ls6 springs are .580
Old 08-01-2009, 01:30 PM
nastychevelle's Avatar
yah i think they'll work
Old 08-01-2009, 02:56 PM
My95Z's Avatar
I wouldn't do it, their is way more than just max lift to picking a spring. That is a pretty aggressive cam with 220+ on intake 230+ on exhaust and on a 110 LSA, a little too aggressive for the 90 pounds or whatever the LS6 springs seat at.
I'd look into Comp or Pac's that'll drop in, a valve spring is one of the last areas you want to fail, even if it doesn't totally fail valve float/bounce will kill hp.
Old 08-01-2009, 03:04 PM
Cobra R's Avatar
Gm recommends spring part# 12586484 which I am pretty sure is the stock replacement spring for a LS6
Old 08-03-2009, 04:50 PM
Last C5's Avatar
Your lift will go up to .555 which the LS6 springs will handle, but you are getting a little close to the edge. PAC 1216s are good to .600 and the PAC 1518s are good to .650.
Old 08-03-2009, 08:13 PM
VincesSS's Avatar
Try it if you dare, but there is a possibility they won't work and you'll just float valves a little and you'll have to change them. Then there's the possibility they float or drop into your pistons and you'll have to buy a new set of springs for your new motor anyway.
I would try to find horsepower somewhere else.. good luck!
Old 08-04-2009, 10:42 AM
thanks for the input guys i think im jus gonna keep it the way it is for now, then later put in a bigger cam and the right springs for the cam. I've decided to go with a set of 243's instead of rockers.
Old 08-05-2009, 09:41 AM
Cobra R's Avatar
I had missed the 1.8 rocker part. I would have to agree that I would run a little stronger spring than stock LS6.
Quick Reply: ASA Cam with 1.8 rockers, will ls6 springs work??
