Ported LS6 oil pump... worth it?
On an L33?
I plan on running an L33 5.3L Ls6 intake, TSP 228r cam, TSP pushrods and PAC beehive springs. Is the $150 oil pump really recommended? Or is the truck oil pump the same, better, or worse then the LS6 pump?
thanks for any input (tried searching, all that comes up is FS threads)
Jeff
Jeff
It's not a bad idea especially if your current oil pump has a lot of miles. However a ported LS6 pump doesn't flow more oil since it's a positive displacement pump. The porting simply reduces friction basically making the pump consume a little less power from the crank. The higher oil pressure is from putting a different pressure relief spring inside the pump.
