Rear brake question
Rear brake question
how do i take off the caliper? my rotor broke and is coming apart from the back side and makes an awful noise when i drive i can almost pull it off the assembly. I tried undoing the 2 bolts on the caliper but they just seem to turn and turn.
any help is appreciated.
thanks i used a set of adjustable wrenches to hold it while i turned and it came loose. Now i cant get the caliper bracket off, the bolts won't even budge.
Save the manuals!
Nope - just normal wrenches.
FYI - When you replace the rotor, you'll need to check the e-brake play and adjust it for the bore on your new rotor, if necessary. You do this by pulling on the actuator lever on the back of the drum with your new rotor on. If you have more than 3 mm of play, you need to tighten it up or vice versa.
