Headers Installed...Need Help Tuning
Hi,
I just installed my long tube headers and I have pulled off the egr/air. I borrowed a HP Tuner from a friend and I was wondering if anyone has a tune I can go off of....what i need to turn off and such to not have the check engine light come on anymore. Thanks for your help!
Under the Engine tab, then General..go to EGR and select Disabled.
(If you got rid of the catalytic converters, not sure on high flow cats)Back to the Engine tab, go down to Fuel Control, then COT. Disable COT.
Also, under the Engine Diag tab, select the DTC tab and you can see all of the codes that can be turned off...
I think that's all that needs to be done.
