What is this plug and wire for?
Old 08-02-2009, 09:09 AM
Libertysyclone's Avatar
Default What is this plug and wire for?
This purple one isn't the starter wire, my starter wire was labeled from the guy who trimmed my harness.
They both are in the same loom and it has a heat reflective tape on it, if that helps.
TIA
Old 08-02-2009, 11:49 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
looks to me like it's for the crank position sensor
Old 08-02-2009, 12:05 PM
LS1Fury!'s Avatar
Do you realize how many connectors are that style plug?
What is it next to or where was it located?
Old 08-02-2009, 12:14 PM
500@10psi's Avatar
alt. maybe
Old 08-02-2009, 01:18 PM
RPOWU8's Avatar
Looks like the crankshaft position sensor. Should have a light green, yellow, and dark blue/white stripe wires attached.
DJ
Old 08-02-2009, 01:19 PM
ssdeuce74's Avatar
I agree looks like connector and power wire for the alt. get an idea of where it will be under the hood and check another camaro
Old 08-02-2009, 05:17 PM
2002ws-6's Avatar
That is for sure the crank postion sensor harness. It's easier to remove the two 13mm bolts holding the starter in place and expose the sensor connector. It is against the block behind the starter
Old 08-03-2009, 12:28 PM
If its for the crank sensor, what Is the single purple wire?
I dont think its for the alt, as the wire doesnt seem long enough
Old 08-03-2009, 12:45 PM
Tough Mudder
Hilton's Avatar
Maybe for the starter? The starter has an 8mm bolt on it for the wire coming from the ignition. I think it's purple. The red wire goes to the big terminal. There will also be a black wire from that same loom. It has a funny shaped end on it that looks too long. It needs to be grounded to the block.
Old 08-03-2009, 01:14 PM
2002ws-6's Avatar
yeah the small wire with the eyelet is the starter selenoid wire thats the one that basically turns the starter on.
