Fuel pressure problem. need help!!
Old 08-02-2009, 01:18 PM
Lamaro_Z28's Avatar
Default Fuel pressure problem. need help!!
my z28 has been hesitating and wont start the first 1-2 tries depending on how long it sits but it will always start on the 3rd. so i did a fuel pressure test and at idle it had 36psi and when revving it went up to 42-43psi. i know thats not what psi it should be. so my main question is what psi should it be running at? also im pretty sure that means i need a new fuel pump??
please helpp
Old 08-02-2009, 02:22 PM
2001NBMZ28's Avatar
What year? LS1's should be 55-61 key on, engine off. Fuel filter changed recently?
Old 08-02-2009, 02:23 PM
LS6427's Avatar
Not neccessarily, you could just have dirty injectors. Time for an entire can of Sea Foam in a 1/4-1/2 tank of gas.
Run it out. Then change the fuel filter.
Old 08-03-2009, 01:33 AM
Lamaro_Z28's Avatar
its a 97 lt1 and do your think a dirty filter can cause your car to not start until the third try? but ill try Sea Foaming it and see if it works
Old 08-03-2009, 08:24 AM
2001NBMZ28's Avatar
LT1 is different, maybe you can find the answer here: http://shbox.com/1/4th_gen_tech2.htm...essure_testing
