ABS Delete ?
Old 08-02-2009, 02:12 PM
Thyme_CA's Avatar
Default ABS Delete ?
Car is a 1997 T/A.
I see the SJM Manufacturing ABS delete kit, is that the only one out there ?
I hate the way this cars ABS works and want it gone ! Plus it's big and ugly in the engie bay !
Old 08-03-2009, 10:24 PM
theblur98ss's Avatar
When I cut mine out I just T's the front to both fronts and the back to both backs. Cleaned up the engine bay a ton.
Old 08-04-2009, 09:01 AM
sroach20's Avatar
you didnt use a proportioning valve?
Old 08-04-2009, 09:02 AM
sroach20's Avatar
Originally Posted by Thyme_CA
Car is a 1997 T/A.
there is another company that does one but it costs allot more money.
Old 08-04-2009, 02:30 PM
Thyme_CA's Avatar
Well looks like I'll just order it from them then !
Thanks!
Old 08-04-2009, 05:32 PM
No proportioning valve. I don't see any difference in braking.
Old 08-04-2009, 06:58 PM
SJM Manufacturing Inc's Avatar
Thyme CA,
Thank you for your interest in our products. I believe you'll find our kits are complete and our customer support is informative.
A proportioning valve is an important component in the braking system. Stock, the ABS controller biased your brakes. Internally, it included valving to control the vehicles needs. When you remove/disable ABS, you remove these components and the ability to adjust front/rear pressures via the controller. This is why adding a valve is important.
Incorrectly biased brake system increases stopping distances, increases uncontrolled braking and can create hazardous braking situations.
Old 08-04-2009, 11:19 PM
35th SS's Avatar
SJM kit on both cars here.thanks Steve.works good no problems here.
Quick Reply: ABS Delete ?
