T400 Pan That A Temperature Can Be Installed???
I heard that there was a T400 pan made in which you could screw a temperature sensor into. I've had no luck locating one, any ideas.
Drill a 1/2 hole in the side of your existing pan (or an new one) and install this. 1/8 NPT is the size of most manufacturer's temp senders... PLUS you get a drain.
http://www.summitracing.com/parts/BMM-80250/
LS1Tech Sponsor
I have deep aluminum pans in stock and will be more than happy to drill and tap it for a sensor. It comes with a pan gasket ,deep filter adaptor,and bolts.Cost is 109.95.
Greg
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
