A4 Shifter problems...
Ok i will do my best to explain what is going on with the shifter. It is very loose and has alot of play in it. It will be lighting up as if its in neutral when its in OD gear. Its the same way with all the other gears. Also when i am in first gear and go to shift into second i must go past second gear and then pull it back before it will go into gear and also in every other gear. If you watch the light on the side it looks like i go all the way up into D but its not actually going into drive gear. This has been going on for probably a week and when i got home tonight my car will not go into park. It goes all the way up and seems to be in park but rolls forward. I dunno if something is loose or broken. Any help would be appriciated! Its a pain and i want to get it fixed so i can park my car without any worries. Thanks!
Derek
Derek
i had this problem awhile back too. i took my car to a local transmission shop and they found a bracket loose on my tranny. they only charged me $25.00 to just to tighten up.....lol.... i thought for sure my transmission was jacked too and they could have easily taken alot more money out of my pocket. Lucky they are a honest shop. if shifter cable bracket loose ,i'm sure that can cause your problem. hope this helps.
