LT1 F-Body Rear Brake question
Old 08-03-2009, 12:05 PM
kcarlasc's Avatar
Default LT1 F-Body Rear Brake question
So I changed my rotors and pads this weekend on all four wheels and ended up with some some noise from the back that sounds like the brake sensors.
When I took the rear pads off I failed to notice which pad goes where, one with a metal tab and one without, assuming thats the wear sensor. I went over to the other side of the car to look at those pads and neither had a sensor on it.
So the question is two fold... Which pad is the inner, the one with or without the sensor and if its on the wrong side would that cause the noise?
Thanks...
