Diesel Techs Needed in Houston Area.
S! LS1-Techers!
Crown Staffing (Houston) has 3 Diesel Tech jobs open we are looking to fill ASAP! If you or someone you know is looking for a job in the field. Please contact Litza Davison @ our Greenspoint location. 281-260-8018.
Info here:
*Diesel Mechanic - (will be working on trucks)
$17-30/hour DOE, Temp-Hire, Monday-Friday 7-3:30pm
(290 and little york area)
Need resumes.
__________________________________________________ _______________
This one is on eastex freeway ( Hwy 59 before 610) . 2 positions available:
Temp-Hire, Mon-Fri.
Diesel Mechanic/Shop-Foreman ( working on trucks.. exp on international
engines, CAT engines, Caterpillars, Mid-Management exp. to run and work in
the shop, order parts, prepare orders, talk to customers. 5-7 years min
experience. 2nd shift from 1:30pm-10pm) $17-22 DOE
Diesel Mechanic (will be working on trucks, 5-7 years min exp.) Might work
on 1st shift from 6:30am-3:00pm, or 2nd shift from 1:30pm-10pm. $17-22 DOE
Need resumes.
Thanks from the folks @ Crown Staffing.
Info here:
Need resumes.
Temp-Hire, Mon-Fri.
Need resumes.
