milling heads?
Old 08-03-2009, 08:42 PM
VHslow's Avatar
Default milling heads?
I have a '04 silverado VHO with a LQ9 6.0, The stock 317 heads are 72cc giving it a 10:1 compression ratio, I have to pull the heads off to get broken header bolts out, So while there off Does anyone know how much I can have milled off the heads without causing valve clearence issues?
The truck has a TSP 233/239 .598/.603 lift
TIA James
Old 08-03-2009, 10:53 PM
elias_799's Avatar
just get some 243 or 241's. you should be pretty happy with aether one of them.
Old 08-03-2009, 11:27 PM
02*C5's Avatar
Safe .0001 that helps some but usually you want the deck milled to match the cam specs
Old 08-03-2009, 11:28 PM
VHslow's Avatar
I'm not looking to spend money on new heads right now, the 243's dont flow much more than the 317's and i can have them milled for $50
Old 08-04-2009, 04:00 PM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
For a stock head I would not mill more than .020" off of them.
