removing ABS...how?
Old 11-20-2003, 03:21 PM
2001CamaroGuy's Avatar
Default removing ABS...how?
I want to remove the ABS system from my 01 Z28 (3 channel) and replace it with a proportioning valve. I have a few questions for anyone who might have already done this:
1) Once the ABS "pump" unit is removed, how do I keep the "ABS INOP" light from coming on (or will it come on)?
2) I "think" the stock master is a duel chamber design (one piston for the front and one for the rear). One line coming out of the master is larger than the other so which should I use for the front and which for the rear (I would think the front would get the larger due to the front calipers requiring more fluid capacity)?
3) What flare are the lines (are they single or double flare) and what sizes am I dealing with?
Old 11-20-2003, 09:59 PM
Larry's Avatar
http://www.mustangmods.com/data/440/absdel.jpg
This is how I removed the ABS. You will get an ABS INOP light and brake light.
The lines are 3/16" and 6 mm. The 1/4" fitting works on the 6 mm. No flaring is required. These are high pressure compression fittings.
(1) Swagelok union tee SS-300-3 $17.90
(1) Swagelok reducing union SS-400-6-3 $8.50
Houston Center Valve and Fitting, 713 527 0233. Ask for Shonda. Tell her it's the same as order number 97179975. Invoice number 401345. Shipping was $4.07.
Note: Order an extra set of ferules just in case your lose one. They are pretty small and easy to drop.
Let me know if you have anymore questions.
Larry
Old 11-20-2003, 10:35 PM
Larry....thanks a BUNCH!!!!
I looked at your pic but didn't see a proportioning valve. Where did you mount yours (or did you use one)?
Old 11-21-2003, 03:10 AM
Larry's Avatar
I have yet to get a proportioning valve. I need to get one. I can stop pretty hard but haven't tried a panic stop yet. I'm sure the rear tires are going to skid first without the valve.
Old 11-21-2003, 12:54 PM
S_J_H's Avatar
Smile
I also used high psi compression fittings.I got mine from www.Mcmaster.com
They also have the proper 6mm fitting.
Simply cut the flare ends off the stock lines with a tubing cutter. Then use common sense to fit them to the new compression fittings for a nice clean install.
#5182k737- Stainless Yor-lok 3/16" compression Tee-$18.36
#5269k311- Steel 6mm to 1/8" NPT male - $2.84
#5182k793- Stainless Yor-lok 3/16" to 1/8" female NPT-$6.77
You can these order online.
Steve
Last edited by S_J_H; 11-24-2003 at 02:35 PM. Reason: Had mis-typed one part number.Above part numbers are now correct.
Old 11-22-2003, 01:42 PM
thanks guys
Quick Reply: removing ABS...how?
