Nitrous Oxide - Tr6 or tr8???
gtrucks
08-04-2009, 12:47 PM
WHICH spark plugs IS BETTER FOR NITROUS NGK TR6 OR TR8???
Spd-Kilz
08-04-2009, 01:04 PM
I know next to nothing about nitrous, but I doubt there is any way to answer this question unless you provide some information on your car and nitrous system.
Grant@NitroDaves
08-04-2009, 01:11 PM
Depending on how much you want to spray and what has been done to the engine, the TR6 is good to about 75hp with bolt-ons. If your going to do 100-200 I would go with the NGK BR7EF (http://www.nitrousoutlet.com/catalog/product_details.asp?group=26&model=101&dept=11&product_id=3469). 250+ go with the NGK B8EFS (http://www.nitrousoutlet.com/catalog/product_details.asp?group=26&model=101&dept=11&product_id=3598). There is no TR7 or TR8. The TR6 is a projected plug and you will have better luck with a non-projected plug such as BR7EF or B8EFS
JonCR96Z
There is a great way to answer it. TR6 is not a nitrous plug. As far as which nitrous plug is better, there are too many variables to say. It all depends on what your engine wants.
Whats your motor and nitrous setup?
gtrucks
08-04-2009, 01:19 PM
depending on how much you want to spray and what has been done to the engine, the tr6 is good to about 75hp with bolt-ons. If your going to do 100-200 i would go with the ngk br7ef (http://www.nitrousoutlet.com/catalog/product_details.asp?group=26&model=101&dept=11&product_id=3469). 250+ go with the ngk b8efs (http://www.nitrousoutlet.com/catalog/product_details.asp?group=26&model=101&dept=11&product_id=3598). There is no tr7 or tr8. The tr6 is a projected plug and you will have better luck with a non-projected plug such as br7ef or b8efs
thanks
gtrucks
08-04-2009, 01:23 PM
there is a great way to answer it. Tr6 is not a nitrous plug. As far as which nitrous plug is better, there are too many variables to say. It all depends on what your engine wants.
i have a 5.3l full bolt-ons cnc 243 custom cam cold fusion nitrous Plate setup 200 shot
JonCR96Z
08-04-2009, 01:34 PM
Start tuning with at least an -8. I'm assuming you're trying to get a big heavy truck moving and probably on pump gas. You may end up back at a -7 when it's all said and done, but you'll be safer until you get to that point.
gtrucks
08-04-2009, 01:42 PM
-8 of ???
JonCR96Z
08-04-2009, 02:07 PM
8 heat range. B8EFS.
gtrucks
08-04-2009, 02:12 PM
ooo ok thanks man
BAKED
08-04-2009, 04:32 PM
I agree^^^^
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
