Turbo K-Member question
Sorry if this is posted in the wrong section....
Just curious as to what good or bad experiences people have had with the BMR Turbo LS1 K-frame. It looks like I will need a different k-frame to route a 4" DP, and am just wondering what (if any) problems people have experienced with this unit.
Thanks.
Thanks.
They should be no issues for a daily driver at all. I'm running a 4"DP through the driver's side on mine. I did have to massage it at the steering shaft but it's alot better then the plain BMR K I was running before for clearance.
I have broke 3 of the original design BMR k-members.We have the new turbo k-member in the street car and i can tell you it's made a lot better than the first ones. We have had zero issues.
Thanks for the consideration
Thanks.
Thanks.
Like everyone else has pretty much said you will have no problems street driving this or our standard K-member.
If you have any other questions I can help answer please feel free to ask
I had one of the original ones of my stock powered daily driver and the welds came apart by the drivers side motor mount this caused the whole motor to sag and my harmonic balancer was grinding on my stabilizer bar. After that I don't run anything BMR on my car. I would go with a different one like the double tube ones.
Apparently, the early ones had issues...but many have had zero problems with the newer design. Thanks to everyone for sharing their experiences with this part. After much positive input from you all, I ordered the km013 unit from BMR. Now, I'm looking forward to FINALLY getting this project moving (literally).
Thanks again everyone.
