How to raise low boost setting with sts kit??
Old 08-05-2009, 11:19 PM
vipvegas's Avatar
Default How to raise low boost setting with sts kit??
Built engine almost done I wanted it to be around 9psi on low side and 12-14 when I hit the switch. I know I can do the high setting by turning there included valve. Do I need to replace the wastegate spring? what pound if so?
Old 08-05-2009, 11:42 PM
great421's Avatar
Default Bingo!
Originally Posted by vipvegas
Built engine, almost done. I want the STS boost values to be around 9 psi on low side and 12-14 psi when I hit the switch. Do I need to replace the wastegate spring? If so, what pound value?
Yes, replace the wastegate spring - the wastegate maunfacturer (Tial) can supply the # value.
They were good to me when I spoke with them...
