whats the biggest cam i can go with
Looks like his 1st post, cut him some slack....Frans96ss is right bud, you will need to upgrade the springs if you plan on runnign an aftermarket cam. If you find a cam, you can pick the necessary springs from there. LS6 cams can be pretty good though if your looking to keep it stock.
make sure you check the lift if you go any bigger then .615 .620 i would go with double valve springs... Just bought mine through TSP with a cam springs titanium seals and retainers, push rods and seals for $689.
It almost not worth doing a cam if your going to keep it real close to stock. I think MTI has a stealth cam that sounds like stock but you probably still need springs. And dont forget about the pushroads.
can this be made? hydraulic roller durations 245 249 with lifts 480 480 or 500 500 on a 110 LSA + 2 or 4 and fit the stock heads milled to +11.3:1 CR with or without flycutting ..... if it can be done then LOL you can even go bigger if those springs will take it
hmmmm .... an idea ... might be stupid
You can also throw in the COMP XR277HR 224/228 .534 .537 112. If the LS6 heads you presently have are the hollow and sodium filled valves then they must have the yellow valve springs correct. Those springs are rated at .570 maximum lift and would work great with this cam.
