F-Body Exhaust Manifold 3 bolt flange drawings
Old 08-06-2009, 10:05 AM
fasteddy51's Avatar
Default F-Body Exhaust Manifold 3 bolt flange drawings
I was fortunate to get some pdf files of the exhaust manifold 3 bolt flanges for the Camaro and TransAm. I believe they are for the 2000 to 2002 manifolds. I have a set of 2001 manifolds, and these dimensions fit my manifolds. I am currently looking into a metal fabrication shop to make a set for me. I am installing a 2000 5.3 truck motor into a Monte Carlo front stub welded to my 1955 Chevy Truck. I am using the F-Body oil pan setup and exhaust manifolds. I am going with the MSD box and carbed intake setup.
File Type: pdf
File Type: pdf
Old 08-06-2009, 11:41 AM
DGGM WX3's Avatar
I've got some flanges I cut off of a stock exhaust system. They'd be great to build your new system off of. If you want them for $20 + shipping, let me know.
Old 08-06-2009, 12:45 PM
rockytopper's Avatar
I agree just go to a salvage yard and have them cut off the cats or buy the ones above. It will be much cheaper than a shop fabbing them from scratch. Unless you plan to have them produced in quanity and start selling them yourself.
Old 08-06-2009, 04:54 PM
fasteddy51's Avatar
Yeah, I agree. I have been looking for a set all over here in Kansas City, but the F-body cars I have found they cut the exhaust at the Y pipe joint. I will try and purchase the set listed above. Thanks for the advice!
Old 08-24-2009, 07:46 PM
Mustang Hunter's Avatar
Do you know if these will fit a 98 Z28? Trying to get a bolt on system going for the cats and I cant find these ANYWHERE.
Old 09-18-2009, 04:00 PM
omore001's Avatar
fasteddy51, thank you for your post, those pdf's are coming in very handy. I am going to have some exhaust manifold flanges made as it is damn hard to find any off an old Y-pipe.
Old 09-18-2009, 04:19 PM
Isolde's Avatar
I'm having the same problem. I have the manifolds, but nothing past, so I'm making my own.
Old 09-19-2009, 05:16 PM
Blownz28man's Avatar
I went to a welding shop and they cut some out with a cnc plasma cutter type machine. I got 4 of the for 40bucks.
Old 10-26-2009, 10:33 AM
TurboZ28408's Avatar
i have some laser cut f-body manifold flanges
Quick Reply: F-Body Exhaust Manifold 3 bolt flange drawings
