P102 MAF Low Circuit Input
What does this code mean?
I've traced all the wiring, everything plugged in and cleaned the Maf off. I've cleared the code twice and it keeps coming back. Is there anything I can do to get rid of this code besides replacing the MAF? Should I just turn it off with LS1 EDit?
thanx
thanx
Have you checked your fuses in the engine bay? You can also check the pink wire on your MAF harness to see if you get 5 volts. Chances are your MAF is fine; it's just not getting any power. I would NOT turn off the code with edit. Are you also throwing any O2 sensor codes?
thanx
thanx
