moser 9" axle removal?
how to you pull out the axles since they are interference pressed in to the housing? it is a self contained bearing. it might be easier if my backing plate wasnt in the way btw its on the driver side and i accidentally hammered the longer pass. axle into the d. side and its about 3/4 of the way in and not wanting to come out
they make a tool that you can connect to the lug studs and ****** them out but obviously you don't have one just like me, lol. what I did was remove a few of the backing plate bolts to create a hole, then I slid a thin 6 inch punch through the hole from the backside and placed it on the axle flange where the lug studs are seated. I then just beat on the punch slowly until the axle came loose. its a pita but just have patience with it and it will come loose.GL
