Need to pick a cam for 409", 300+ n20 setup
Well ill take alot of your opinions on a good cam choice. The car will make weekend trips around town for fun...
409", all forged iron block setup, absolute speed x2 heads, ls6 intake, etc
direct port 300-350 nitrous setup
What cam would work well in this setup?? I was thinking a 236/242 , .580-590 lift @ 112 lsa
Or do i want 114 lsa still?
We are putting a solid roller cam in our 409ci iron block motor. we have plans to hit it with a 300 shot. cam specs are 253/259 .645/.645 112LSA.
That cam you are looking at should be fine but you will want to use race gas of 110 octane
Actually the cam does have an effect on octane requirements as it affects the dynamic compression ratio. I however am not going to speculate what your octane requirements will be without more specific information.
I suggest doing a search.There has been alot of cam talk over the past couple of months.
Actually the cam does have an effect on octane requirements as it affects the cylinder pressure . I however am not going to speculate what your octane requirements will be without more specific information.
the cam does affect you octane requirements to a point, but not not nearly as much as the amount of spray you are going to use and your mechanical compression ratio. with a 350 shot, you are looking for trouble with pump gas. depending on your mechanical compression ratio you should be able to run NA on pump gas just fine. once you go over 11 to 1 you should keep an eye on knock retard. anything over 12 should have atlease over 100 octane but not always.
Oh i definately agree....
Im running a dedicated fuel cell with 114 in it for the nitrous. I'll probably run 100 unleaded in the tank as well for the bottle..
Mainly i was curious if a 250@ .050 camshaft is too big for this ls1 that drives on the street
Originally Posted by Aidan
Race gas for what??? Cam sizing shouldnt affect octane required???
well i guess streetable is what it means to the the driver. i drove around a 69 camaro with a 260/270 solid cam in it for years and i considered it streetable. to me streetable means as long as i can buy gas on the street to use in my car. if it lobes hard or if it runs at 4500rpm on the freeway so what. hehe. i would think a 250 would be a great street cam.
