Compression ratio?? Need advice please
I have a stock Ls1 346ci engine and Im planning to get texas speed PRC LS6 stg 2.5 CNC ported cylinder Heads. After adding these heads, what will the COMPRESSION RATIO in the motor be?? This will help Me pick a specific camshaft for the heads, any help please, thank you
LS1Tech Premium Sponsor
With the stock short-block and GM MLS head gaskets you can get them at 64cc chambers and that will net you about 10.7:1. Of course thinner gaskets and milling can bump your compression up from there!
What camshaft were you considering?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
With those PRC LS6 stg 2.5 CNC heads? The Torquest camshaft from the following is what I will use:
215/231 .631/644-118lsa
232/234 .646/.612-112
235/243 .621/.624-113
239/242 .649/.609-112
Which one is the Torquest camshaft for those heads??
Thanks
Thanks
You've really skipped over the lower 220's cams that will really make some torque at useable rpms.
