Vic JR PVC routing
Vic JR PVC routing
Guys,
Right or wrong, I routed my pvc setup exactly like factory, only adding catch cans prior to the check valve connection at the throttle body. I have since changed from an F1 setup to a KYTP S88 front mount setup with a Vic JR intake. Could someone please show me how they routed their pvc system so I can complete my mission. There isn't a provision to hook up the vac line to the front of the intake as my FAST or factory intake had. I have a Nick Williams 90 TB. I hope ya'll can guide me through the finish line,
Thanks in advance!!!
Guys,
The vic has 2 vac ports. The 1/2 inch on back I used for the brake booster. The little one on the side I used for all the other little vac connections, using t's and the sort. The pvc from valve cover to valve cover comes up the pass side to a check valve then to the intake (factory), the Vic has no provision for this. I'm just wanting to see what everyone else did.
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
