550 hp
550 hp
well i set this goal for near future for my 01 camaro that has only boltons, the car is a complete street car it will see track maybe twice a year, i use it rarely, only for my club meets. taking in concideration i want to reach my goal the most economical way possible keeping my ac, that does not mean i want to skimp on anything, my main goal is to have a car that once its tuned be as reliable as a stock car, i want it to last a million years.lol.. ive been thinking of going with a procharger setup on low boost with a forged short block 347 or going with a 402 ls2 based, the dilemma im having with the last one is everything that it will take to convert over to a ls2 as opposed to staying with ls1 based motor and reuse lots of parts, im planning either way to buy a shortblock put it in myself and go get it tuned.
im reading what lots of dyno numbers on the 402 and it looks hard to get it to 550 completly NA.I see that some have got it there but on really high lifts. i really dont want to strain my motor and have it at the ragged edge at all time. i have a few friends that are helping me with putting in the engine and all, i have read and absorb lots of information and i want to tackle my first build.
I would awsome if you guys could help me out share some ideas. so Im ready when i pull out that checkbook...
Rather than try to do this yourself, the only economical way to approach a project like this is to entrust someone who has proven results to spend your money only once. So many people start out on projects like this only to under estimate the commitment (and I mean $$$$$) to actually hit all four points. Buying the same parts 2-3 times is the worst way get there 'economically', so either create a plan and stick to it (no matter how long it takes) or be prepared to bite the bullet.
Best of luck!
Best of luck!
Best of luck!
Good luck.
I have a ls7 427 w/ TFS 235s, big cam and very good parts that does not make 550 rwhp. I think w/ exhaust changes it will past that number but I always laugh when people say how easy it is to make 550+ w/ a 402/408.
Before you venture into this process, let me give you one piece of advice:
Fast, Reliable, Cheap <---Pick any two
Hope you do well reaching your goal.
It's not THAT much to convert over to a newer (gen 4) engine...if you're building the engine, you can have it built with whatever crank reluctor you want (24x to match your cars computer), and then there's just some minor wiring harness changes...your accessories bolt on, your headers will bolt on, the engine mounts are the same, tranny bellhousing pattern is the same, f-body oil pan will work too...and if it's already built with a 58x wheel on the crank, you can get the conversion box to make it a 24x signal for the cars computer anyways.
like everyone else is saying 550rwhp is no joke and takes alot of time and money (less time with more money). The easiest and most reliable way is a forged shortblock and low boost. That will give you a pretty easy 550rwhp and be pretty easy on parts. N/A is going to be a beast to unless you can do something with 440+ cubes and pretty exspensive heads.
thanks for all your advice guys, i was checking out golen engines and they have some attractive packages over there 408 for less than $5000 and sdp has short blocks for $4000 for a 383.
talking to my friend yesterday he was telling me about the reluctor wheel and how easy it is to have all the stuff done to fit the car.
im getting a 57 chevy truck next year or maybe a c10 1969 so thats where i plan on putting the ls1..im leaning over to 408 ls2 block l92 heads and a 600' lift cam and see where that leaves mel, after sitting down and thinking about it to get to 50 extra horsepower to meet the 550 goal Im going to have to invest about 5000 more for the procharger atleast. now is the time to try to find somebody that will build such a thing. there is so many builders out there that is hard to know who to trust.i dont have deep pockets and its taking me a while to save up for something like this so I want to make the right choice
