No leak possible bad slave?
I have a 98Z with 77k. I changed the master and try to bleed the system and still no clutch.
This is the third master i have put. When i disconnect the master the peddle is not rock hard.
My question can slave be bad with no leaks?
Possible defective master?
if its the 3rd master and still same issue im gonna have to go with the slave. i went through the same thing, i would fill the fluid, pump until my leg hurt. get **** poor if any pressure. then i found it the slave leaks internally, so you wouldnt see the leak. i would recomend changing the slave, having 3 bad masters is very unlikely
