Have new tubular suspension, where to get hardware?
I am starting over with a new PA tubular k-member, BMR upper and lower A-arms, and Spohn solid motor mounts as well as QA1 shocks. I ordered some new hardware for the a-arms from Spohn but would like/need some new stronger hardware wherever I could replace some of the old 100k mile, rusty, rounded off bolts. I don't think the motor mount bolts I have that go from the k-member to the solid motor mounts will work and I don't have any bolts at all for the solid mounts to the block. Also I did see that Spohn does include k-member and some motor mount bolts when you buy a K-member and have e-mailed them about trying to buy those but no response so far. I know I can probably get some of these from the hardware store but rather just get it from the manufactures if I can?
Hello
Its easy! just get in touch with the manufactures of the parts that you are using. I am sure that they offer aftermarket hardware upgrades. And will be more than glad to help.
Take Care
Brad
Take Care
Brad
