L33, TR224, Ls6 Intake, Injector help?
Old 08-08-2009, 09:39 AM
v8envy's Avatar
Default L33, TR224, Ls6 Intake, Injector help?
I am getting ready to put my L33 5.3L together, I have been pointed to the TR224 cam, I will source a used z06 intake unless I can score a fast 90/90 setup for a fair price, just curious what injectors I should be using, and if any one has any insight on my cam choice if there is something better for a 2500lbs rx7 with t56 I would likle your opinion as well!
Old 08-08-2009, 11:39 AM
blackLS1m6's Avatar
You can use the stock injectors for your setup, but if you have bigger plans down the road i would buy bigger injectors. The tr224 will do well in your setup i wouldnt go any bigger in a 5.3
Old 08-08-2009, 11:43 AM
01ssreda4's Avatar
At least use stock 28.8s, not the 26ers. My 224 was maxing out my 28.8s so i upgraded to SVO 30s which flow somewhere around 36 at our pressure.
Old 08-09-2009, 06:52 PM
v8envy's Avatar
what can I find the 28.8's in? is it something I can find used?
Old 08-09-2009, 07:35 PM
RsSean's Avatar
00-02 Camaros I do belive.
Look in the for sale section, you can pick them up pretty cheap for a good set.
Old 08-09-2009, 08:21 PM
LS1MCSS's Avatar
98's had them. 99 and 00 had the 26's, then they went back to the 28.8.
Old 08-09-2009, 10:18 PM
01ssreda4's Avatar
I have the set that came out of my car for sale. PM me for more info
Old 02-13-2010, 07:06 PM
paNX2K&SE-R's Avatar
v8envy: Were you able to get your engine put together yet?
Quick Reply: L33, TR224, Ls6 Intake, Injector help?
