05 GTO in S14 DBW throttle wiring help
I have an 05 Ls2 in a 97 S14 240sx i have the pedal but not the correct\complete wiring information. I purchased a new pigtail for the pedal along with the missing blue ecm connector from: http://www.eficonnection.com/eficonn..._pigtails.aspx
the colors on the pigtail are:
Blue
Light blue
Purple
White /black stripe
Brown
Yellow
im not sure which wire goes to what on the blue connector harness.
Ive seen a few pinouts for throttle position but the connectors seem to be different along with the wires. The ones ive seen are 10 socket using 6. My connector is an 8 socket also using 6
Blue
Light blue
Purple
White /black stripe
Brown
Yellow
try asking http://silviav8forums.com/forum/index.php several guys on there have done this. i have a 96 240 with 04 gto.
And the answer is.....
OK, it turns out that the pigtail I had bought from eficonnections was wired basicly upside-down. They had the same wire colors so I went with it. Lesson learned. So I rewired it according to the diagram posted above from alldata and hello throttle. I made a little diagram to help anyone else in my situation that is attached.
The following users liked this post:
hotrod 55 (08-21-2023)
