what do you think of this setup heads cam...and what NOS system should i buy
Old 08-08-2009, 11:26 PM
bat!'s Avatar
Default what do you think of this setup heads cam...and what NOS system should i buy
I just put on etp 215's 56cc
cam is 244/256 631/631 on a 112
Is this too much cam for the heads and will it work good with a nitrous system?
What Nitrous system would you buy if starting from scratch and buying a fuel system? Wet? Dry? direct port?
I have all bolt-ons with a fast 92/92 setup
motor is all forged with new stock crank.
Old 08-10-2009, 09:30 AM
Nick@HSW's Avatar
How much are you looking to spray? CI? We're missing a lot of info here...
Nick
Old 08-10-2009, 02:44 PM
bat!'s Avatar
looking to spray up too a 300 shot on a 347
Old 08-10-2009, 03:15 PM
Nick@HSW's Avatar
Without a doubt, do not spare expense and do a direct port.
Nick
Old 08-10-2009, 04:08 PM
jmill96Z's Avatar
Go Direct Port. You won't regret it.
Old 08-10-2009, 05:17 PM
Chris@NitroDaves
Guest
Posts: n/a
For what you have and what you are looking to spray....my first suggestion would be to suggest a direct port setup. If the fuel system on the car right now will support teh mods you have now then instead of redoing the entire fuel system i'd suggest going to a dedicated <--Linked to site ) so that away you know your covered on fueling for the nitrous.
Here is a link to over 7 pages of direct ports that we have done
http://www.nitrousoutlet.com/installs/index.asp
-Chris
