Spohn TA: Front to back clunking?
Hi, hope someone has an inkling on this...
At low revs, like 1500-2000, my whole car shakes front to back ( bucking ) and there is metallic clunking noises coming from below the floorpan and rear end.
I have a pretty big cam ( see sig )and some of this may be caused from "cam reversion" and all, but something seems awfully loose.
Certified Performance has checked everything a couple times and say everything is tight with the Spohn Extreme Duty TA mounts and all. ( They did install rubber pads under the TA-to belly pan mount to reduce metallic noise, maybe that's causing more of a problem?)
Could it be a sloppy rear end? (My 4:10 gears were quiet but now howling and seem sloppier than before- maybe going to 3:73's now )
Transmission loose splines?
U Joints? ( Fairly new and it's an extreme duty chrome-moly one)
Just wondered if anyone had similar problem they fixed.
Well, now I just read this: ( sorry I lost the page and author )
" I think someone needs to mention how the Moser bolts slip. Even though we may not want to offend any particular company, it is a fact that the Moser design uses four bolts instead of two bolts that go directly through. Many readers of this site have still fallen victim to this including myself. Even when you buy a UMI torque arm for a 12 bolt there is a warning at the top of the instructions that torque arms broken due to moser bolts slipping are not covered under warranty."
What does that mean the bolts slip? What can be done about it? Wire the bolts like they do on aircraft? Spot weld them? ( LOL )
Yeah, part of the reason is to give myself a bump, no traffic yet!
if you have the helm joint version of the spohn torque arm in the front where it mounts to the crossmember, that is your problem. there is no fix for that because you are hearing the play in the joint as your car moves from accel to decel. mine did the same thing and i sold it.
Thanks both of you guys....
I think it's poly like Sprayed 99's.
It seems like that's just wrong, I wonder if Spohn has a solution coming...I'll contact them.
Best, Rambo
Best, Rambo
I have the same setup. You probably need to tighten the nut below the front poly mount where it connects to the cross member. Its a locknut so it may feel tight but if you get it a little tighter 90% of the clunking goes away.
i have the same issue, and its the bushing at the transmission crossmember. just havent had time to replace it. it definitely is annoying as hell, and every time i go over a bump it clanks real loud LOL. sounds like an old pickup truck.
OK, now I'm out of the country so can't call Spohn...So, I'm once again contacting them by email and requesting they have a tech stop on in here and help us all out.
tech@spohn.net
My TA is the #405 long tube header version with poly end.
I did not notice this before, they also have a "Del-Sphere" End for $22.95.
Spohn, Would this DS end be the better ticket for noise and slop? Or just tighten it more as Fall Line suggested?
tech@spohn.net
Here is what the shop did in an effort to reduce the bucking and clunking noise. Just Photochop here for the idea ( It did not help )
Nice try but bad idea probably in retrospect: The added slop could stretch the bolt holes larger and even make it worse, so we are removing the rubber pads.
Wow, look how beefy the Spohn cross arm plates are compared to the existing thin sheet metal floor car brackets. ( just above the rubber pads)
Seems that should be reinforced too? Otherwise it seems the Spohn is just overkill, as those brackets are just wimpy.
Spohn tech, when you come in please also comment on these two points. Thanks.
Thanks, Rambo
Thanks, Rambo
Its just the TA, I had the same version on my car and with an auto it was hardly noticeable, but when I swapped to M6 I couldn't stand the clunking. I sold the Tunnel Mount TA and bought a full length UMI arm and no more clunking
Trust me I installed the rubber between the floor and the TA and the noise was still there, adjusted the pinion angle thinking that was it, tightened everything up with a torque wrench, and the noise was still there.
Sorry but I don't think there is a fix for it
Spohn Tech come on IN !
Thanks, Turnin20s.
Does the Full length UMI mount to the tail of the tranny or tunnel mount, or.....? I heard of the tranny tail housing breaking over 500hp is a concern.
Is it adjustable? Maybe that's part of the slop. I actually don't know if I need my adjustable, my driveline pinion angle was -1 to zero with a previous solid BMR TA which I sold.
If a Spohn Tech comes in here - would your "Del-Sphere" End for $22.95 help? If not, how about an RGA number and a refund? You guys sold "poly" as quieter and it's just not man!
I'm overseas, but if any of you guys with same problem on a Spohn TA feel like calling them, their number is 1 800 365 6064. If ya do, Please Let us know what you find out.
With the UMI body mount that I have the clunk is pretty damn loud... and I drive an automatic with a stall... not sure how much louder it could get on a m6
My Spohn TA did it pretty bad until I sold it, when I upgraded to my MWC 9" and chromoly torque arm.
The only "fix" I found was to constantly torque the living **** out of the adjustment nut at the crossmember. It was always working loose and clunking around.
Rob (Bad30th)
Rob (Bad30th)
Spohn tech come in please!
Maybe I'll just be sure my pinion angle is on the money then just spot weld the m***** f**er!
Emailing Spohn AGAIN! Hello Spohn! Come on in!
