150shot dry timing question
Old 08-09-2009, 03:28 PM
87Lt1Monte's Avatar
Default 150shot dry timing question
Im planning on using a nitrousoutlet halo where the air filter is. Will i need to pull timing for this shot or will the maf pull timing and add fuel?
Old 08-09-2009, 05:33 PM
MelScrilla's Avatar
I know for sure that the maf wont pull timing. you have to get tuned for a shot with a device that pulls timing when the kit is activated.
Old 08-09-2009, 06:32 PM
Robert56's Avatar
You can pull timing via spraying the MAf and it works great. it will not effect your n/a tune at all. You need no aftermarket timing pull box, it's free. You do have to have access to, or own a tuner program to set it up. But you can have it done by your tuner if you don't own a tuner program. My full write-up how-to can be found on google, or at my site should you know what that is.
Robert
