LS1 conversion radiator? tranny side used as a oil cooler ?
Old 08-09-2009, 04:20 PM
Restricted User
Lawnboy's Avatar
Default LS1 conversion radiator? tranny side used as a oil cooler ?
I have a Procharged 01 SS
I installed the bigger core SLP/LT1 radiator a while back.
OK my car is a 6-speed, and the SLP radiator comes with the tranny cooler part pluged off for manual LS1 cars.
I wanted to run a line from my oil filter area to the tranny side of the radiator and back out to a port drilled and taped into the oil cap as a return to cool off the engine oil a bit.
Now will the tranny cooler built into the SLP/LT1 radiator make a difference to cool off the engine oil? i know its small but it does work to cool off tranny fluid
what do u guys think??
Old 08-09-2009, 05:15 PM
davidws6's Avatar
Default Trans oil cooler
I think it would but dunno how much. Anything if your FI would prolly help !
If ya just dump it back into the valve cover, won't that lower your overall pressure n volume going through the engine?
Why not use the lil fitting above the oil filter and pipe a tube to and from. That way your cooling it B4 it goes back into the engine ?
My 2 cents.....
Old 08-09-2009, 06:47 PM
Restricted User
Lawnboy's Avatar
i know about the fitting above the oil filter that would go (feed) to the SLP/LT1 Radiator - tranny cooler, but where would i return it out of the radiator??? i was thinking back to the oil cap/valve cover
Old 08-10-2009, 06:39 AM
mikedamageinc's Avatar
I used the tranny cooler on my radiator for power steering cooler and put in a straight hose instead of the factory SS cooler. I thought about the oil cooler idea but I would rather a seperate oil cooler when I decide to run it, I think it would be more effective.
Just my .02
Quick Reply: LS1 conversion radiator? tranny side used as a oil cooler ?
