Grind Going in 2nd
Grind Going in 2nd
On my 96 TA, When i hit 2nd gear Fast it makes a slight grind and then goes in, this only happens when i hit it fast. It doesnt matter if im going 10 mph or 60 mph it does the same thing.....syncros? I was told it could possibly be a bad clutch? only does it going into 2nd though. any ideas? Thanks in advance.
blocker rings, I have an '01 and I had tha same problems, the blocker rings wear easily, switch to carbon ones, when I did that it all stopped except for 5th and 6th for some reason I still have to have the tailshaft taken out every few months to change the blocker rings, it sucks....they make a new tranny from tremec that doesnt have any of the problems we have with our T-56....mines been built by D&D with all the hardest stuff and still 5th n 6th does what ur talkin about....but I never had a prob with 1,2,3,4 gears, so it may be syncro's but I know my 5th does what ur talkin about soon as I do a 130mph run on the highway for about my 5th time then it starts that but if I let the rpm's drop to 1,000 it goes into 5th smooth
