Need a pic of the stock cats on a '98-'02 Z28, & will they fit an LT1?
Old 08-10-2009, 03:29 PM
Brangeta's Avatar
Default Need a pic of the stock cats on a '98-'02 Z28, & will they fit an LT1?
Can someone post a pic similar to this one of what the stock cats look like on a '98-'02 Z28 or SS?
this pic is under a '93-'95 Z28.
this pic is under a '96-'97 Z28.
I'd really like to see the layout underneath a '98-'02. And also, do you know if they will bolt up to the stock exhaust manifolds on a '97 Z28?
Old 08-10-2009, 03:41 PM
goldmecham's Avatar
they are not the same and wont just bolt up
Old 08-10-2009, 03:54 PM
Brangeta's Avatar
Do you think they can be retrofitted with some modification? And do you have a pic?
Old 08-10-2009, 03:59 PM
goldmecham's Avatar
i dont have a pic crawl under your 2002 ss and look. you would have to cut them out and weld the cat in and if you only have one cat lt1 your wasting your time get a 3in in/out cat.
Old 08-10-2009, 04:01 PM
goldmecham's Avatar
if you need a pic go to rockauto and look for them they have pics
Old 08-10-2009, 04:15 PM
Brangeta's Avatar
They'd be going on a '97. I don't want to jack up the SS to take a look. It's lowered and my head won't even go under it...
Old 08-10-2009, 05:43 PM
goldmecham's Avatar
i know the pass side one when you cut it out will weld in the pass side of the 97 but not sure on the driver side
