New motor , do i need to retouqre head bolts???
Old 08-11-2009, 12:43 AM
Restricted User
Lawnboy's Avatar
Default New motor , do i need to retouqre head bolts???
New forged LS6, built for boost
stock ported 241 heads with GM MLS gaskets and arp studs.
do i need to retoqure the heads, i put 600 break in miles so far.
Please help
thank you
Old 08-11-2009, 12:50 AM
ramdaspadhye's Avatar
As long as you torqued them to spec the first time around and used sealer on the threads, I don't see any reason to retorque them.
Old 08-11-2009, 09:04 AM
LS1-450's Avatar
Since they're ARP's & not the stocker stretch bolts, I usually check mine just to be sure. Although, will say that I have never had an ARP stud nut need retorqing after the initial time, as long as the torqing proceedure was used. Might want to check 'em after going full boost a couple of times. Good-luck
