New Street Setup: OE Wheels 17" ZR1's
I just got the new OE Wheels Polished Deep Dish ZR1's for my street setup.
Front 17x9.5 with 275/40/17 Nitto RII's
Rear 17x11 with 315/35/17 Nitto Drag's
The rims were priced right and the 17" tires are so much cheaper than 18's I just had to switch over. Plus I was looking to get more rubber on the ground to help my 408 hook-up better on the street. I'm more about function than looking good with big rims. I did run 11.1@123 with a 1.65 60ft Sat night on this new setup. I usually run my drag pack, but wanted to see how these would do.
Just a heads up, if any vette guys decide to run these you will need to dimple the upper ball joint flat in the rear for clearance. That only takes about 5 good hits with a hammer and your done. Easy enough.
Enjoy the pics.
Enjoy the pics.
sultan(ZR-1)KSA me to me to please . which dimple bang on
The rear upper ball joint just needs to be hammered flat. You will understand when you look at it.
The C4 ZR-1 is one of my favorites. Modern Classic.
Actually looks good on your C5!
If they made an 18x11 for the rear to go along with the 17's up front I'm sure a lot of C5 guys would make the switch.
