Get a Free Fluid Film Racing Cap!
Get a Free Fluid Film Race Cap!
Post a pic using a regular sized can (11 3/4 oz.) of Fluid Film on your vehicle and get a free Fluid Film cap! Not a bad deal, huh?
We only sell through distribution. If you can't find anyone here, you could try one of our online dealers for purchase.
Can I use the can u send me for free ? cause that sucker never ran out lol. Been use on 3 different cars battery, 6-7 cars door hinge. around my door house hinge, that sucker havent ran out yet lol.
Glad to hear the can has lasted. (If there is a problem with the product, it's that it lasts too long, at least from the manufacturers point of view.)
However, in order to get the hat, it has to be a regular sized can.
mmm maybe another samble ?? ..
btw .. i test your product .. it seem to be good but i got some questions .if i spray at the engine compartment the dust will stick to the surface like some other products?? .. also when i apply it, it cleans some of the surface rust .. but is there another of your products that can remove all the rust !? .. if i apply your product to bare metal how can i remove it ?? (for example if i want to paint it after applying FF), im looking forward into buying a gallon of your product because it's cheapo and worth the money .. not like those wd-40 cans that stop working after just one use
Because Fluid Film leaves a wet, non-drying film, I would recommend gently rubbing it in on areas where you don't want it to come off on hands or clothes, or where you don't want dust to stick. Fluid Film never gets gummy or tacky, so even when wet, you will not get a heavy dust build-up.
Fluid Film will loosen existing rust and stop it on the spot from going further, but it is not a remover. We do not have any other products that will remove existing rust.
If you would like to remove the product before painting, you could either pressure wash the material off, use a warm detergent wash or mild solvent such as mineral spirits.
Boy, am I glad you asked. Fluid Film is an amazing corrosion preventive and lubricant. it has completely unique properties due to its lanolin base and solvent free manufacturing process. It is classified as non-toxic and non-hazardous, and is safe to use on paint, plastic and synthetic rubbers.
Fluid Film stops and prevents corrosion on contact, on all metal surfaces. It lubricates and stops squeaks on contact as well. It never gets gummy or tacky, instead retaining a super slick consistency that penetrates metal pores, sealing off all oxygen and protecting metals from calcium chloride, salts and moisture. It always remains active, migrating to inaccessible areas, lasting a minimum of twelve months on battery terminals and areas protected from UV rays.
You can find out much more about our product by visiting our website at www.fluid-film.com.
If you've never tried it and live in the US, just PM me for a free sample can.
