!!!!!!!!! Unbeatable engine sale---- Fall 2009!!!!!
XHP Short block sale:
If you are ready for the best deal of the year check this out. Call or PM us if you have any questions:
408 6.0L Iron Short blocks
http://www.xhpsolutions.com./product...cat=341&page=1
…GM 6.0L Iron Block, Eagle 4340 Crankshaft, Eagle H-beam Rods, Mahle -12cc 4.005 Pistons w/ Mahle rings $3395
…GM 6.0L Iron Block, Callies Compstar Crank, Compstar Rods, -2cc 4.030 Bore Diamond Pistons w/ Diamond Pro-Select Rings: $3595
418 LS3 Aluminum Short-blocks
…GM LS3 Aluminum Block, Eagle 4340 Crankshaft, Eagle H-beam Rods, -4cc 4.080 Bore Diamond Pistons w/ Diamond Pro-Select Rings: $4595
…GM LS3 Aluminum Block, Callies Compstar Crankshaft, Compstar Rods, -4cc 4.080 Diamond Pistons w/ Diamond Pro-Select Rings: $4695
A conversion kit may be needed with your short-block.
We also have 5% off specials available on LS2/LS7/LSX builds if needed.
Take 5% off the following packages:
454 LSX http://www.xhpsolutions.com./product...cat=341&page=1
XHP Performance Crate http://www.xhpsolutions.com./product...cat=325&page=1
PM or call!!
PM or call!!
