first real suspension piece ordered; kind of excited...
Just placed an order the the first real suspension piece for my car, UMI poly/rodend LCAs.
After I completed the T56 swap, I could really start to feel where the suspension in the car was starting to fall short on hard launches. Any kind of hard launch it would wheel hop like a SOB. Keep in mind the suspension is completely stock minus poly endlinks, poly swaybar bushings and a 1LE bar up front. Excited to see how these LCAs affect how the car drives.
I think a tunnel mounted TA is next; after replacing the TA bushing with a poly piece it appears to be bent? Unless the stock TA has a natural bend, I cant remember?
1 Post
because our cars love to twist under a hard launch.... SFCs stiffen the car up. First mod I did to mine and with stock power I noticed a difference. not to mention it prevents body warp.
You are sooo very right! We could talk/type about this all day. And a lot of people start with a part were their budget will let them. But in the end SFC's LCARB, Torque Arm.....Will come into the plans. Thanks again for choosing UMI Performance and if you have any other questions feel free to ask and I will be more than glad to help.
Thanks
Brad
1 Post
judging by the mods in his sig, he SHOULD have SFCs. there is a thread about first mod and im pretty sure SFCs are up there. Just givin the guy a heads up... that should at least be next on his list.
because there is almost no way around sfcs no matter what setup you go with. They WILL make a difference for the better. For a single pair of parts these make one of the biggest differences.
i started to get some very small dimples up high on my rear qtrs. i realize now its from those hard launches and not having sfc's.
MHO ... subs won't fix the problem. It's urban legend ...
The dimples in the QP are from the back half leveraging over the rear spring and shock points. Visualize where SFCs stop and then visualize where the weight of the body is loaded. It becomes obvious then.
A full tank of fuel, a huge sub with multiple amps combined with a pot hole or speed bump factoring in lousy shocks and soft springs is what causes the problem.
Just because you got turned out into believing you needed them, doesn't mean others should follow.....
SFC are debatable....and if you knew anything you would agree.
So I'm sure you have valid points but it's really a coin toss the individual should have the right to make.
Not something I would continue pushing as a first mod...
1 Post
T-top cars its a must. i've seen cars get destroyed because they don't have SFCs and they have a t-top car... First thing I did... easy to install and cheap, and I noticed a launch difference without a doubt.
Man I don't want to fan the flames here, but I had a 97 bird before I got my 99 bird. I made the decision to get SFC's for my new toy thinking I had some extra money to spend so why not? Looking back on the decision to do them saved the uni-body of my 99. My 97 flexes, body panels are warped and waved, doors don't shut properly, and interior parts rattle anytime it moves. My 99 needless to say doesn't do any of that. I have had it for over 40k now and the body is in exactly the same shape as when I got it minus the rock chips. No one ever said it fixes anything. It prevents the body from sagging and twisting that's it. These guys are trying to save you from the stuff that happened to my 97. If you don't want the help then by all means you don't have to take it. Just first hand experience that they and I are trying to share.
Its an OK mod for peace of mind but to say SFCs are the end all be all and your car will fall apart without them is retarded. Most of those quarter panel 'dimples' are from either the situation described above w/ shitty shocks or from some idiot pressing down on the flimsy sheetmetal there. I've had noises the dealer has troubleshooted....they push down there to make the suspension move...and guess what I have little dimples there about how it would look if someone pushed down on it.
SFCs are NOT necessary on these cars. Replacing the crappy shocks IS.
